Power Consumption (Idle and Gaming)
Putting a realistic, repeatable load on a GPU to get a decent idea of its real world power consumption and thermal output has long been something with which we've experimented here at
bit-tech. We've found that synthetic benchmarks such as FurMark thrash the GPU constantly, which simply isn't reflective of how a GPU will be used when gaming.
It's such a hardcore test that any GPU under scrutiny is almost guaranteed to hit its thermal limit; the mark at which the card's firmware will kick in, speeding up the fan to keep the GPU within safe temperature limits. Conversely, simply leaving a game such as Crysis running at a certain point also isn't reflective of real-world use. There's no guarantee that the GPU is being pushed as hard as other titles might push it, and the load will vary between play-throughs.
We used to use the Canyon Flight test of 3DMark 06, as this was a punishing and repeatable test. However, we've now adopted
Unigine's Heaven 3.0 benchmark, as its DirectX 11 features will stress all the parts of a modern GPU. We use the default settings and a resolution of 2,560 x 1,600. We then hit the Benchmark button and watch the power draw from the wall between the grass field scene and the second dragon scene - this is the toughest portion of the test for both Nvidia and AMD hardware.
AMD Radeon HD 7750 1GB
AMD Radeon HD 7770 1GB
AMD Radeon HD 7870 2GB
Nvidia GeForce GTX 650 1GB
AMD Radeon HD 7950 3GB
AMD Radeon HD 7970 3GB
Nvidia GeForce GTX 660 Ti 2GB
AMD Radeon HD 7950 3GB with Boost
Nvidia GeForce GTX 660 2GB
Nvidia GeForce GTX 670 2GB
AMD Radeon HD 7970 3GB GHz Edition
Nvidia GeForce GTX 680 2GB
Zotac GeForce GTX 660 Ti 2GB Amp! Extreme
AMD Radeon HD 7850 2GB
EVGA GeForce GTX 650 Ti 1GB SSC
Nvidia GeForce GTX 690 4GB
71
72
75
76
80
80
80
80
80
80
80
81
85
86
87
90
20
30
40
50
60
70
80
90
System Power consumption in Watts
112
126
145
166
173
192
205
224
227
232
240
241
265
273
314
389
Thermal Performance (Idle and Gaming)
We also have GPU-Z running in the background, and leave the Unigine benchmark running for ten minutes to record a peak GPU temperature. We present the temperature as a delta T (the difference between the temperature of the GPU and the ambient temperature in our labs).
6
8
9
10
10
10
11
11
11
11
12
14
14
15
16
8
10.5
13
15.5
18
Delta T in °C
AMD Radeon HD 7970 3GB GHZ Editon
29
37
40
41
41
42
43
44
50
53
54
54
55
57
63
Delta T in °C
*as there's no stock model of the HD 7850 2GB, it is not included in these graphs
Read our
performance analysis.
